Manual Transmission - Centerforce or Spec or Ram?
vettesmakeemwet
04-24-2005, 05:12 AM
Has anyone used the Centerforce Dual Friction clutch? The Spec 3 seems pretty stout but I've seen some bad posts about them. :drive:
ls1mojo
04-24-2005, 05:30 AM
Do you know there's something called a search button or where you born yesterday. :eyes:
vettesmakeemwet
04-24-2005, 05:37 AM
Don't you mean 'were' you born yesterday? And no I didn't know, I just joined LS1TECH a few days ago.
ls1mojo
04-24-2005, 05:43 AM
The search feature is a well known valuable technical resource I recommend you use it.
vettesmakeemwet
04-24-2005, 05:53 AM
OK, so it looks like Spec 3 is the way to go. But should I get carbon or ceramic? Which will last longer? Also, my flywheel (Centerforce Steel) will only have about 1,000 miles on it when I install the Spec, will it need to be resurfaced?
ls1mojo
04-24-2005, 06:02 AM
An organic friction material will give you better feel and street manners, which is ideal for the majority of drivers. A ceramic or tougher material (ie, kevlar) can easily support additional horsepower and rpm down the road however may chatter and have more of an on/off nature.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
