100mm MAF for the LSx engine..............
Old 04-24-2005, 08:38 AM
Quickin's Avatar
Default 100mm MAF for the LSx engine..............
Why do companies keep making the 90mm MAF???
Why doesn't someone step it up to a 100mm MAF......then someone needs to make a 100mm intake and TB.
Isn't advances in mods the goal?
Cams, pistons, heads, exhaust, stroking, boring, nitrous, etc..... all this doesn't mean dick if you can't move the air
Old 04-24-2005, 08:47 AM
Another_User's Avatar
I think the reason this has not been done is because MAF sensors are not very accurate at low airflow velocities. By increasing the diameter of the MAF beyond a certain point you reduce the velocity through the MAF and (I think) introduce turbulence at low speeds. This would cause innacurate readings.
Old 04-24-2005, 09:01 AM
Quickin's Avatar
So does this mean that a 90mm MAF is the limit to what we will see?
How big is the MAF that a C5R race car uses on its engine?
Old 04-24-2005, 09:24 AM
Cody Brooks's Avatar
how about 2 small MAF's then. that should help keep turbulence down.make a special wiring harness with built in module that will take the reading from the 2 MAF and add then together and send them out so that it looks like what 1 MAF would read.
Old 04-24-2005, 09:28 AM
Lostpatrolman's Avatar
That has already been before on ls engines....
Old 04-24-2005, 09:40 AM
1CAMWNDR's Avatar
The C5R does not have a MAF. Besides, it is 427 cubic inches so it will flow more air at low engine speeds than a 346 inch motor therefore negating the low air velocity problem .
Old 04-24-2005, 09:46 AM
Quickin's Avatar
I have a 436, bigger than the C5R. So what do they use and can it be done on my 436?
Old 04-24-2005, 12:30 PM
I doubt it is the limit, but they will probably need to switch over to some other way of doing it. They have done the two MAF thing already.
Old 04-24-2005, 02:36 PM
9 Second Club NA
Dragaholic's Avatar
I wasnt even aware that they make 90mm MAF, who makes them? Any better than 85mm MAFs?
Old 04-24-2005, 02:45 PM
DriveATransAm's Avatar
vipers have 2 mafs, dont they.
Old 04-24-2005, 03:21 PM
There was a thread on here about that the other day. It sounded like whoever made it went out of business.
Old 04-24-2005, 03:46 PM
((((((Administrator))))))
CRAGER's Avatar
I have the FAST 90 intake/tb and a 85mm Granatelli MAF on my 427. Gained 20rwhp, 515rwhp (40 degrees outside) to 535rwhp (around 85 degrees out), I know about correction factors and I know there was still a difference that day.
Plus the throttle response was insane, like I installed a higher gear.
What intake set-up do you have now?
Peace,
Craig.
Old 04-24-2005, 03:47 PM
CRAGER's Avatar
Two throttle bodies, thats why.
Peace,
Craig.
Old 04-24-2005, 03:58 PM
soundengineer's Avatar
at the point of a 100mm Maf...its probably smarter to go with a MAFless tune...
Old 04-24-2005, 04:57 PM
9 Second Club NA
Dragaholic's Avatar
Nothing right now, but I have the Fast 90mm intake and Nick Williams throttle body on my garage floor waiting for me to install it. Need to get a bellow and MAF to complete it. Not sure what MAF to go with or if I should go with a speed density tune. I'll have to give Mike @ G-Force a call and see if he has experience with it. If not, then I guess I'll just have to decide on what MAF to get.
Old 04-24-2005, 05:22 PM
From my experience, that would depend on your cam. Lopey cams cause dopey dynamic airflow calculation at low rpms. It doesn't matter for the strip, but driving it around town can be a real PITA. But HPTuners sounds like it has some groovy stuff going on with a hybrid Alpha-N and speed density hybrid. If it works like they say, it could be particularly useful for tuning some wild combinations.
Old 04-24-2005, 06:36 PM
Quickin's Avatar
Peace,
Craig.
If you're asking me, I have an LS6 intake and a Z06 85mm MAF.
Old 04-24-2005, 06:41 PM
ls1 joe's Avatar
Vipers do not have maf sensors. They are speed density closed loop programs.
Old 04-24-2005, 06:44 PM
Quickin's Avatar
Well than how do I go with a dual throttle body for my engine?
Or is the 90mm plenty for my set up. If I can get more flow, meaning more power, from the dual type maybe I'll do it.
How much $$$?
Old 04-24-2005, 07:08 PM
CRAGER's Avatar
You should get a 90mm intake and tb, either FAST or LS2. Should work really well with your displacement.
Peace,
Craig.
