At what RPM should you dump the clutch?
I'm sure it all depends on the driver. I'd assume the higher the RPM the harder it is on the clutch and driveline. what's the best for a good launch w/ street tires?
the appropriate RPM that you can make the tires stick to the ground with...
On ET Streets, I can stick 6k rpm clutch dumps all day long... on the street, I can't feather it out of the hole in first gear without lighting the tires up if I go anywhere near WOT.
Originally Posted by ArcticZ28
The RPM you should launch at is directly proportional to the amount of money you have to spend on clutch, tires, gears, and a new rear end.
