clutch chatter
clutch chatter
i put 110 miles on the first day with installing a spec stage 3 with aluminum fidanza flywheel and upgraded hydrolics, around 80-90 miles in i noticed a chatter, is it normal or did i align it wrong?
this is on a 1999 camaro z-28
Uh... its a widely known thing that the spec(if not most) aftermarket clutches chatter pretty badly for the better part of the break in period. Break in should be 400 miles of city driving up to 1000(if you have a 3f) without dumping or really being rough on it. som even say not to take the engine over 3500-4000rpm. After the break in, if it is still chattering, many say go somewhere safe and dump it a few times(like at the track). It will get better. My 3f has almost 500 miles on it and its getting better by the minute.
