What are good o2's to run.
I have put new headers on & thought about putting in new o2's since I have been running leaded gas through the old ones. Is the boasch o2's any good, that is all the parts stores sell around here. I don't think I'll be running leaded gas through them any more. But maybe when new heads go on. How about those denso's are they good?
Is this the right #'s 234-4025 L 234-4087 R Are these correct denso's. Are the wires longer than stock wires like the bousch 13444's? I checked on oem O2's they were 150.00 retail, thats to much.
I actually switched to the bosch corvette rears 02's to put in my fronts cause my slp extensions were failing everything up and the vette ones didnt work for me either. I am probly going to do a closed loop on them.
I don't know that mine are bad. When I went to the dyno last time & got it tuned, the A/F gauge on the dyno was not working properly so we could'nt get a correct reading. But the plugs are pretty white when I took them out yesterday. I also have ran racing gas through it mixxed 50/50 with 93oct. I also just installed FLP Lt's & figured why not. Need GOOD advice.
Originally Posted by ddelallata
Go buy new ones at the dealer and stay away from Bosch 02s.
My original O2's got fouled to all heck and after some minor searching I realized I should be running O2's made for the rear C5 bank. Ended up with Bosch part #13111. I put them in and my horrid problems went away immediately. Am I going to end up replacing them with something else? I havn't happened across this claim before.
