6 Month Old Gas
Old 04-25-2005, 05:29 PM
pdd
pdd's Avatar
Default 6 Month Old Gas
my cars been sitting for 6months. ill be firing it up tomorrow or wed finally will the old gas be alright or should i put sum octane booster in it or something? im at 11:1 compression if that matters.thanks pat
Old 04-25-2005, 05:32 PM
Grimes's Avatar
You'll probably be okay, but next time put some stabil in there before you let her sit for the winter!
Old 04-25-2005, 05:36 PM
Ryan02SS's Avatar
Grimes hit the nail on the head. Stabil in the proper amount and you will never have to worry. Is the tank full? If not I would fill it up with new gas and add a $5 bottle of Chevron Techron Fuel System cleaner just to be safe.
Old 04-25-2005, 05:40 PM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
My car sat for 10 months before the new motor went in.....I have 11 to 1 c/r and the gas is fine.
Old 04-25-2005, 06:23 PM
GM Muscle's Avatar
I forgot to put gas stable in mine last year and I fired it up the other day. It started like it has been sitting for a day a not 6+ months. It's been running real good and the A/F ratio is still perfect & smooth but I'll probrably run some fuel system cleaner through it anyway once all the old gas is gone.
Old 04-25-2005, 07:21 PM
Beast96Z's Avatar
Plannin on firing yours this week too huh?
Old 04-25-2005, 07:27 PM
ss rally red's Avatar
I worked at a motorcycle dealership for 10 years in a previous life LOL but what was funny was that on a lot of bikes after 6-7 months the gas would turn green in color/tint and smell just like terpentine, it seems to be worse with bikes than cars.
Old 04-25-2005, 07:34 PM
pdd
pdd's Avatar
YES FINALLY
Old 04-26-2005, 06:39 PM
pdd
pdd's Avatar
ok im gonna put like 5 gallons of 93 octane in with the old gas. should i through in injector cleaner also just so the old gas wont gum up my injectors? by-the-way, i bolted up the exhaust today and put on the head on i had fixed. looks like rain tomorrow so i hope ill have the first cruise thur
Old 04-26-2005, 07:15 PM
Patman's Avatar
Just drive it gently for a while, since that fuel will have lost quite a few octane points. My suggestion would be to drive it on the highway to burn off a lot of the fuel quickly. Keep topping it up with fresh fuel every 100 miles, and by the time you've put about 300 miles on it you should have a much stronger mix of fuel in there and then you're good to go.
Old 04-26-2005, 09:51 PM
White.Lightning's Avatar
Dump some 110 in there!!!!!!
Andy
Quick Reply: 6 Month Old Gas
