9" Rear end, what studs?
Old 04-25-2005, 11:18 PM
Shon Herron's Avatar
Default 9" Rear end, what studs?
Got a 9" rear here and need longer studs, thought it was a normal 12x1.5 stud but when we order from ARP or Moser the knurl is too small, it is a .530 knurl. We looked for a 7/16" stud but nothing in that knurl, so do we have to go to a 1/2" stud?
If we go to the 1/2", will it fit thru the rotor and stock wheel? we would have to get some acorn styles in 1/2 to run the stockers...is that it?
Is that my options?
Old 04-26-2005, 02:59 AM
JMBLOWNWS6's Avatar
I have 1/2 stud's on T 20 lugs.
Old 04-26-2005, 09:34 PM
bigdsz's Avatar
I have the 1/2" screw in studs 3"long.
Old 05-17-2005, 11:08 PM
Big Daddy's Avatar
I have 1/2 20 studs 3" long, I have an extra set of 10 if you want to buy them, got them from moser $25 shipped
if you need references I'm Book'em Dano on Ls2
Old 05-18-2005, 07:27 AM
Screw in or press in? what size knurl if press in?
Old 05-18-2005, 11:52 AM
Big Daddy's Avatar
screw in, no knurl, my 8.8 was a screw in, but the fronts will not fit the 1/2 20 without modification
studs come with lock washers
Quick Reply: 9" Rear end, what studs?
