Spec Stage II & Aluminium Flywheel
Old 04-26-2005, 09:26 AM
miami993c297's Avatar
Default Spec Stage II & Aluminium Flywheel
It is going in asap, I will let you know how is goes & what kind of feeling with the pedal after the 500 miles traffic driving ( Break-in Spec recommandation) :
Old 05-11-2005, 05:56 PM
lsx24's Avatar
Nice!
Old 05-11-2005, 06:02 PM
Cal
Cal's Avatar
I'm putting one like that in right now too . . . are you going to use the shim?
Old 05-13-2005, 02:53 AM
618HAWK's Avatar
This is a good setup, I am currently runing as well. But have to replace it, and up grade. It has started to slip with high power levels. Just went to forced induction with 494rwhp 488tq. Before I was at 375rhwp and 380hp and it held great. Started sliping at upper end of the powerband now with the extra power. So be cautious if you are planing on going after more power might want to think about a stronger clutch.
Other that that this clutch and flywheel worked very well, nice pedal feel and easy on the hookup.
Yes make sure you install the supplied shim, tolerances are tight. It was needed, I know I left it out and it required another removal to install it to get things to work. On top of that it helps keep the heat off of the slave, heating the fluid.
Old 05-13-2005, 07:52 AM
gotzaGTO's Avatar
i recently put this setup on the goat and i love it!! i didnt use the shim, but the petal feels exactly as it did when stock (except for the added firmness that is!) good luck with it and have fun with the breakin period...
Old 05-15-2005, 02:12 PM
lsx24's Avatar
I'll be curious to hear the results, if any different than stock. With the 13 lb flywheel my motor really spins up fast!
Old 05-29-2005, 08:20 PM
Update is there :
https://ls1tech.com/forums/showthrea...02#post2985002
Christian
Quick Reply: Spec Stage II & Aluminium Flywheel
