How can I clean my SVO 30# injectors?
There is no way of really cleaning an injector at home. I have heard of "Sonic cleaning", which is basically someone with jewelry cleaner, but this dose not work.
The best way to do it is to send them to a fuel injection place. It should cost around $10.00 to $12.00 a injector.
Moderator
I think you would need to reverse-flush them (get the
silt off the internal screen) in an aggressive solvent
(but not so aggressive that the materials get hurt).
I made my own injector tester years ago out of junkyard
Ford plumbing. I never tried to run the injectors backward
in it (which would seem to be a matter of the proper
donut and clamping). A gallon of gas and about 4 bottles
of Techron would probably fit the bill for cleaner. My setup
is built into an unnecessarily large equipment suitcase.
Somebody ought to make a cheapo home fuel injector
tester that works off the Schrader of a running car.
Hmmm.....
Hmmm.....
Reverse flow, gravity feed with injector pulsing. Acetone (or carb cleaner.)
Jimmy, you would be nuts to sell something like that unless your LLC. Even then your a good lawsuit away from living out of a box.
way cheaper than buying new.
