SLP lid fitment?
Old 04-27-2005, 02:43 AM
armkneez8's Avatar
Default SLP lid fitment?
SLP lid fitment? What's up guys! I just purchase my first mod on my 2001 SS, a SLP lid and fernco Bellow. It cost me $96.00 in total, not bad. Anyways I tried putting the lid on and I had problems fitting the lid on. The clips didn't want to clip the lid. After a few adjustments the left clip went on but the right didn't. Any Ideas and is this common?
Old 04-27-2005, 02:49 AM
Payne01SS's Avatar
I just installed my SLP lid a couple days ago, took a couple minutes fooling around with the tabs. Just follow the directions it came with, and make sure the tabs in the back of the lid are properly in the holes. Sounds to me like u may not have it properly seated onto the filter.
Old 04-27-2005, 06:20 AM
Rok
Rok's Avatar
make sure the tabs in the back are in and the lid should be inside the bottom lip a little bit. then the clips should stay put.
Old 04-27-2005, 07:54 AM
bbqz28's Avatar
I had the same thing happening with mine. Make sure the front lip is tucked in also. After I made sure the front was tucked in, I have no more clip problems.
Old 04-27-2005, 08:54 AM
Trent's Avatar
I'll be 3rd to say the same thing. Make sure in the front the top piece is tucked inside the bottom piece. This is what will ensure the clips stay on and make a good seal and won't keep coming off like mine did.
Old 04-27-2005, 09:03 AM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
thats so bizarre that what should be the most trusted company has such fitment issues with their arguably simplest product. weird my MTI lid went on without any problems.
Brad
Old 04-27-2005, 03:26 PM
DanZ28's Avatar
I don't think there are fitment issues, more so operator issues as the lid sit's a little diffent on the lower air box, that seems to be most of what I have read anyway. I had the SLP lid and now run the MTI because it fits better with the TNT power ring. The SLP was a better quality lid than the MTI lid IMO...
Old 02-21-2011, 10:11 AM
t-top99's Avatar
I have had issues with my SLP lid since i got the car, the back 4 tabs will not stay in their holes. Its the like the MAF, throttle body and bellows are to long and are pushing it up and out of place, resulting in the entire back of the lid to be up leaving a 1/4 inch gap across the back.(an annoying whistle accompanies this gap from the air sucking through i am running out of ideas here)
Old 02-21-2011, 10:19 AM
ssteven's Avatar
Did you trim the inside of the fernco hose a bit? Its so stiff it doesnt bend quite as well as the SLP bellows. Also you can warm it up with a hairdryer when installing it to bend it a bit.
Old 02-21-2011, 10:21 AM
KRAZY K 2000 TA's Avatar
i have had mine since 2001 and never had a problem? I dont use a maf and also bought my own silicon hoses
Old 02-21-2011, 01:58 PM
skopers3's Avatar
Really curious how this is the first mod for a guy with 871 posts... Holy old thread!
Old 02-21-2011, 02:02 PM
babbage1109's Avatar
It's not. Look at the time stamps. The other guy posted in a thread from 2005....
Old 02-21-2011, 02:05 PM
safemode's Avatar
Must be a slow day because it seems like a number of threads from over a half a decade ago are being revived.
My slp lid like everyone else's is just fine fitting (the rubber weatherstripping material is crap but that's to be expected). If there is any fitment issue it's your bellow that needs fixing.
Old 02-21-2011, 02:28 PM
derck_mullin's Avatar
I think some of it is that the cars are becoming so affordable there are lots of new folks that are coming on-board and reviewing the old threads...heck of a great car/motor combo!
Old 02-21-2011, 07:47 PM
t-top99's Avatar
which piece of hose is this? thank you
Old 02-21-2011, 08:35 PM
bayer-z28's Avatar
Push the lid back all the way. Happened on mine too.
-=EDIT=-
Damnitallnecropostingfawkrz!
Old 02-24-2011, 07:09 AM
t-top99's Avatar
I have pushed it all the way back repeatedly just to watch it pop back out! I'm going to try trimming the bellows this weekend to try and keep them from pushing it out
