3.73 gears?
3.73 gears?
i've 2.73 gears right now..
now, if i change to 3.73 gears, what all would have to be done to make sure that everything else 'knows' about the 3.73s and works with them ? will my speedometer work accurately still, for example?
As far as the spedo, it'll need to be recalibrated...I had my done by a shop that has HP Tuners..You will need to get gears for a series 2 carrier...
Kevin
Kevin
http://www.jegs.com/cgi-bin/ncommerc...87&prmenbr=361
Just go down the page till u see GM 10 bolt and u can see it has different options for carriers.
PCM will need reprogramming. I have heard those hand held ones **** up your computer and will need to be wiped if tune via laptop later. Not good. Use the laptop software.
