where do u have the shift light wires goin through the firewall?
Old 04-27-2005, 03:46 PM
Wnts2Go10O's Avatar
Default where do u have the shift light wires goin through the firewall?
exactly as the title says.
Old 04-27-2005, 03:52 PM
00Z28 Camaro's Avatar
My guess would be thru 1 of the existing openings thats most convenient
Old 04-27-2005, 05:39 PM
Brian2001SS's Avatar
Just below the computer, there is a hole with a grommet. Go through there.
TRMIN8R's Avatar
I have mine going through the rubber grommet on the passenger side right under the computer. Don't try to get it from inside the car, it won't happen, I took a clothes hanger and pushed it through the top and hooked the wire and pulled it through. It makes it ALOT easier.
Old 04-27-2005, 05:41 PM
Moderator
davered00ss's Avatar
I used the hole w/gromet below the PCM on the passenger side. I had no problems pushing it through from the inside.
Old 04-27-2005, 05:42 PM
Brandon Boomhauer's Avatar
just taped mine to a small piece tubing, same idea...
Old 04-27-2005, 06:24 PM
Wnts2Go10O's Avatar
ok its done, man wht a pain in the ***.. not as much as the headers will be tho
Old 04-28-2005, 06:27 AM
Viper's Avatar
Ru driving a camaro or firebird? Snaking the wire on the bird seemed tougher than the camaro guys have it ( after it's inside the passenger side compartment ).
