Biggest Baddest Best cam only cam..........
Old 04-27-2005, 07:57 PM
sandking's Avatar
Default Biggest Baddest Best cam only cam..........
Which cam makes the BEST power on full bolt-ons with the stock unmilled heads? I searched, but could not find much info. Emissions, drivability and flycutting are not issues, I need the most power I can get out of a cam. G5X3? G5X4? F-?? TREX? TSP?? etc, etc??????? I know I will need springs, retainers, lifters, etc, etc. I dont want to touch the heads now, but maybe in the future I will get some good flowing ones. BTW, a th400 and 4:88 gears are going behind the motor. Thanks for the input, Joey
Old 04-27-2005, 08:02 PM
luv2spd's Avatar
I'd say that the T-rex is still king in this department.
Old 04-27-2005, 08:44 PM
Louis's Avatar
The 2 quickest cars on stock heads are running the G5x4.
Old 04-27-2005, 08:48 PM
zamboxl's Avatar
what about the famous ron jeremy?? not the pornstar ok get ur minds out of the gutter people.
Old 04-27-2005, 08:53 PM
sandking's Avatar
Thats good to know, I am leaning toward the LG cam, it is my first choice, but wanted to see what compared to it (if any).
Louis, I need a package with this cam, lifters, push rods, under pulley, timing chain, head bolts, gasket kit, etc, etc. Can you PM me with some pricing?
Old 04-27-2005, 09:08 PM
Sudz's Avatar
crane makes a 310/318 like 800lift cam but if we're talking ls1 specific the trex is a good one.
Old 04-28-2005, 09:14 AM
sandking's Avatar
Is that the F-15??
Old 04-28-2005, 09:37 AM
ablakez28's Avatar
t-rex or g5x4 either one will do what you need. personally i run the t-rex but my decision was easier since the x4 wasnt out yet. i havent seen the track yet on the new setup but it made 430/390 without even having full boltons
Old 04-28-2005, 09:40 AM
Kraest's Avatar
It all depends on what you wanna do.
Bigger cams will make more power, but in a more narrow powerband.
Honestly, the F-15 is the biggest cam I'd ever want in a stock heads + bolt-ons application.
Mike
Old 04-28-2005, 09:44 AM
LSONE's Avatar
does the g5x4 fit under stock heads without fly cutting? how about the F-15? I know the t-rex does, just curious about the others.
Old 04-28-2005, 09:45 AM
PewterZ28's Avatar
I was torn between the T-Rex and the G5X4. I made my decision and just purchased the G5X4. I'm hoping for 10.80's @ 123. I'll let you know how it goes. I'm about 400~500 lbs heavier than Magnus and 01-Z.
Lou, can you tell me what the LSA is of the G5X4 or is it top secret? I could have sworn I heard it was either a 111 or a 108, I can't remember.
Edit: Nevermind, I found the link where you say it is on a 111. https://ls1tech.com/forums/showthrea...light=G5X4+LSA
Old 04-28-2005, 09:56 AM
Josh's Avatar
If flycutting isn't an issue, you're certainly not limited to those you listed, as they were designed to be used without valve reliefs.
I believe the T-ReX is still the biggest, but the title of baddest seems to change from week-to-week.
Josh
Old 04-28-2005, 02:54 PM
ArcticZ28's Avatar
Why not call up a sponsor like Futral and have them make a custom one for your application? You don't have to go with only what is pre-made for the masses.
Old 04-28-2005, 03:21 PM
WS666's Avatar
You wont be disappointed with either the G5X4 or the T-Rex...
If you want an opinion between the two, I would go with the T-Rex. Yes, currently the two fastest are using the G5X4, but Rodney with the t-rex, is right there as well, and goin through a 6 speed.
Old 04-28-2005, 04:35 PM
LS1Tech Sponsor
Slowhawk's Avatar
Also matter's which year heads you have.98-00 don't really like the monster Cams.They seem to work alot better in the 01-02 headed cars.
Old 04-28-2005, 09:17 PM
Louis's Avatar
I wouldnt say that, 01-Z and Magnus have the exact opposite engine packages when it comes to the bottom end.
Magnus is on a 99 or 98 long block with the 85x castings, and 01-z is on the 01 longblock with the 241 castings.
Both make 413 rwhp, both run 10.29s @ exactly 128.48 mph.
Old 04-28-2005, 09:31 PM
sevanseriesta's Avatar
I thought the quickest cam only car was trex is that not what it says on the fastest cam only cars list in the drag racing section
Old 04-28-2005, 09:44 PM
SMOKIN01TA's Avatar
ill say the trex is definaltly the baddest imo, im a half tenth behind but 3 mph up on the other guys at the moment but i have a good 150lbs and im running a stick. just for comparison sake, in 2 identical cars im confident the trex would win. but maby im a lil biased. however the next few weeks shall hopfully prove this with no doubt.
stay tuned for further updates
Old 04-29-2005, 12:08 AM
sandking's Avatar
Year 2000 with the 853 heads. Will there be much benefit with later style heads?
Old 04-29-2005, 11:48 AM
LS69TA's Avatar
The Trex is a good cam, but I just like the Futral cams, that's why I got the FM-15.
