Hptuners and vortech injectors
Hello!Last year a ordered a vortechsupercharger kit with 8 injectors. its 38#injc.
But i dont want the supercharger anymore but still want the injectors. I got a programmer when i bought the supercharger. When im looking at the setup with the hptuners( fuel vs ) it says 38.88 in the first and 39.13 and so on.
But when im reprogram to the stock setup i cant put in this numbers in the stock.
When im puting in 38,88 39,13 and so on from the vortechsetup and push save table.
The numbers will be 38,01 39,00 39,00 Why?
And i cant use the original tabel and multiply it with 1.4371. Ithink it was. it will be the same problem. The number will change when im pushing the save tabelbutton.
Hope anyone can help me.
The numbers go up to simulate a vacuum regulator. If the motor has a vacuum fuel pressure regulator then the numbers are the same all the way accross. if you send me the file ill fix you up for free. jessebubb@yahoo.com jes
