Drilled Throttlebody. From the factory????
Old 04-28-2005, 05:50 AM
fastbasser's Avatar
Default Drilled Throttlebody. From the factory????
My buddy has a 2002 SS Camaro. When we took off the airbox, the butterefly had a hole drilled in it as they do when a cam is installed.
He said he bought the car new. Is this done at the factory??
Old 04-28-2005, 07:57 AM
LS1Tech Sponsor
Slowhawk's Avatar
yes
Old 04-28-2005, 08:12 AM
blkZ28spt's Avatar
All you do with a cam install is drill it out slightly larger. Although it's best not to drill it out unless absolutely necessary.
Old 09-09-2005, 01:28 AM
LS1LUNATIC's Avatar
My throttlebody has a hole in it from the factory.
Old 09-09-2005, 06:56 AM
Billiumss's Avatar
Yes, it's to assist the IAC system.
When you add a mild to big cam, drill it out 2 drill bit sizes bigger and then adjust your IAC tables.
