which clutch is best and do i have to get a new flywheel? please help
i need a new clutch which kind should i get and do i have to get a billet aluminum or steel flywheel when i buy a new clutch? wheres the best place to get all this? if i get an aluminum flywheel what all do i need to install all this? will i have any tuning probs or anything like that?
Well without knowing anything about your hp/tq it's hard to say but IMO a great clutch for a moderate to aggressively modded car would be a SPEC 3F w/ steel billet flywheel. Many of the sponsors here sell them. Give TTP a call they are real good guys http://www.ttperformance.net/ and will point you in the right direction for your setup and they have good prices.
you would want to post your hp/tq and to say if your car is a daily driver and if you are going to run the car at the track. So you can get a better responds and you should go with a steel flywheel with whatever clutch you get.
the more powerful the clutch, the harder it's going to be on your stock flywheel. no matter which clutch you use, if you do decide to stick with the stock flywheel, you should definitely get it resurfaced.
i will run at the track once in a while, i do drive my car pretty much everyday i want a clutch that wont go out when i do hit the track though, i have just 3" exhaust and i will soon have longtubes
