Fans low/hi, what temp to kick on?
Old 04-28-2005, 03:21 PM
VTC_WS6's Avatar
Default Fans low/hi, what temp to kick on?
Well I finally got my copy of Tunercat OBDII and I just started tinkering with it last night. Tried disabling the EGT and AIR systems since I removed all that stuff when I tossed the LT's on, but I still got the SES after 2nd crank. I think I know what I did wrong there but that's besides the point.
What temp are you guys kicking on the low and hi speeds fans on? I did a little searching but didn't find any info specific to fan engagement vs. temp so I was wondering what the status quo for optimal performance. The options I have are:
First Stage Fan On Temp - Over Speed =104.0 C
First Stage Fan On Temp - Under Speed =108.0 C
Second Stage Fan On Temp - Under Speed =112.0 C
Second Stage Fan On Temp - Over Speed =108.5C
Not sure about Over/Under speed though?? Any clarifications?
Old 04-29-2005, 02:26 PM
VTC_WS6's Avatar
bump..
Old 04-29-2005, 05:17 PM
rush7's Avatar
what thermostat are you running? I assume stock since your temperatures are pretty close to that, but I think that would be helpful info.
I just use the settings from the hypertech webpage for a 160*(F) stat which I run...which are:
Fan 1 on/off at: 184°F/175°F
Fan 2 on/off at: 194°F/185°F
If I had a programming tool (a real one), I would probably adjust the fans to come on a hair sooner than that (maybe 2°F, but that's just a matter of personal opinion.
Your settings (converted to Farenheit so I can understand them):
First Stage Fan (Off) Temp - Over Speed =219.2 F
First Stage Fan On Temp - Under Speed =226.4 F
Second Stage Fan On Temp - Under Speed =233.6 F
Second Stage Fan (Off) Temp - Over Speed =227.3F
which is pretty much the stock settings (or close)....
If I were you I would try the on/off temps from hypertech webpage as a beginning point and go from there; they use a more aggressive on/off than stock for their power tuning on a regular stat (which I am still assuming you have):
Fan 1 on/off at: 209°F/200°F
Fan 2 on/off at: 219°F/210°F
Old 04-30-2005, 11:18 PM
VTC_WS6's Avatar
Great info, thanks and yes this is on thr stock T-stat. With only a lid, LT's and catback I don't know how beneficial a 160* thermo would be yet..?
Old 05-11-2005, 09:44 PM
00silverz28's Avatar
great info. I got just what I was searching for. Thanks.
Old 05-11-2005, 11:23 PM
2000WS6Vert's Avatar
My HPTuner and 160 should arrive this week or next. I'm glad I read this!
