SPEC3 problem
Old 04-28-2005, 05:17 PM
baloga41's Avatar
Question SPEC3 problem
installed spec3 last week and i'm brakin the clutch in for 440 , today while i was driving the car the clutch started to act weird , now i have to puch the pidal all the way to shift and some times i have to force the shift in and out with the grinding sound of the gears when i want to force the shift.
what do u think is the reason?? how to fix it ?any body ???
Old 04-29-2005, 12:23 AM
tuffluck's Avatar
clutch isn't disengaging. did you install the shim? if you have an adjustable master cylinder, adjust it out.
Old 04-29-2005, 05:15 AM
baloga41's Avatar
i don't kow if the guy who installed it put the shim but yeah it is not disengaging.if i want to install a shim what would by the thikness of the shim??
Old 04-29-2005, 07:07 AM
Ls1Pwr4's Avatar
The clutch comes with a shim that must be installed at the slave cylinder
Old 04-29-2005, 08:43 AM
baloga41's Avatar
ok i think the guy at the shop did not installthe shim and he could not find it . what is the thinkness of the shim??
Old 04-29-2005, 06:04 PM
ws6firehawk109's Avatar
0.055" according to others in this post:
https://ls1tech.com/forums/manual-transmission/312103-help-asap-middle-spec-install.html
Quick Reply: SPEC3 problem
