Seafoam?
Old 04-29-2005, 10:16 AM
cr0y's Avatar
Question Seafoam?
Car: 1999 Z28 M6 (61k miles)
Just bought the car and would like to do some maintenance. I am getting semi-poor gas mileage and I figure some cleaing couldn't hurt. I know seafoam by some is considered magic in a bottle but I am not sure the best way to go about using it. I would like to get it straight into the motor (i hear the car will blast tons of white smoke, i dont care ) Just wondering how much to use and how to get it in? I have heard using the vacuum from the brake booster. Also, The plugs shouldn't need changed yet but I am still trying to figure out the poor gas mileage (around 13 mpg normal driving).
Thanks!
Old 04-29-2005, 11:20 AM
ttyson's Avatar
search is your friend
https://ls1tech.com/forums/search.php?searchid=1562705
Old 04-29-2005, 11:40 AM
cyphur's Avatar
if you're getting that poor of gas mileage i would definitely pull some plugs and check them out to start with. just b/c they "shouldn't" need changing doesn't mean they don't. if you can find a guy locally that has HPTuners i'd also scan your car to see how you're running(lean or rich or whatever).
what mods do you have done to your car?
Old 04-29-2005, 01:14 PM
cr0y's Avatar
bone stock except for cat back borlas. I am gonna pull a plug and see what I find. Is there any other way to tell if im running lean/rich, and if so, how is it corrected?
