CRAZY CRAZY 4L60E question for you..........
I have a new, 3,000 mile 2004 Trailblazer 4 wheel drive with 4.2 6cyl w/4L60E.
I also have a 1998 Z28 49,000 w/4L60E, tired, w/ 100's of 1/4 mile passes, still shifts/runs fine, 12.89@108mph last week.
Can I swap the 4L60Es ??
Is the 2004 4.2 6cyl 4L60E as strong/stronger/better than the 1998 Z28 4L60E ??
Will I just have to swap bellhousing/tailshaft/??
Or are the cases just totally different & not doable??
My thinking is that the tired 98 4L60E would last a lot longer behind the Trailblazer.
Hmm, I just found out that the Trailblazer TC will work in the 1998 , at 2,200-2,400 stall, so the input shafts are the same too..
Thanks,
Dave
Thanks,
Dave
Originally Posted by SmokingWS6
if the harnesses and input shafts matched, it still would not be designed with as strong of internal components. If it works it won't last long at all in the 98
Originally Posted by rcfast
what are the differences in hard parts?
So I don't see the point of tearing both transmissions down to the tailshaft.
You might as well just tear one down and rebuild it.
