Which Cam for me???
Which Cam for me???
I am looking at the TSP 233/239, TSP 235/240, and the LGM G5X2. My mods include full bolt-ons, TCI SSF 4000 stall, 26in MT DR's on prostars, and 3.42's in the rear. I am gonna spray it as well with a 150 shot. any input would be greatly appreciated.
Katech's don't require rod-resizing, do they? I think new rod bolts will be added to the laundry list when I do a k-member, easy time to do it. If I don't have a cam by the time I want to do my k-member I need to quit school and start runnin guns so I can mod this car more.....
You guys running these big cams how do they behave at slower speeds, ie: cruising while not on the throttle. Just had a 231-237 plus other valve gear etc in sig installed, car also runs a NZL after mrkt ecu. the tuner had one attempt & complained about cam lope, car shudders violently on partial throttle, shakes the whole drive line.
Originally Posted by ls1 1990 VN
You guys running these big cams how do they behave at slower speeds, ie: cruising while not on the throttle. Just had a 231-237 plus other valve gear etc in sig installed, car also runs a NZL after mrkt ecu. the tuner had one attempt & complained about cam lope, car shudders violently on partial throttle, shakes the whole valve train.
My f13 does just fine driving around town at slow speeds. I've tuned it myself and I think it behaves very well for being a bigger size cam.
The only things my MS3 does are:
Hunt for idle after a cold start if I drive for less than 2-3 minutes and come to a complete stop and sit. There is a light just outside my apartment complex that I have to turn left at and it takes a long time to get a green light most of the time. I have to put it in neutral and feather the throttle on cold days. It is perfectly fine another half mile down the road at the next light though.
Slight bucking right at the converter lockup speed if I am cruising at constant speed. Have to accelerate oh so slightly or tap the brakes to unlock the converter.
The tuner and a lot of other mechanics here think the cam is to big, ***** this country sucks. I know i have to install bigger injectors, today i think i found a tuner who doesn't seem to think it's any problem to tune so i'll let him have a go after new inj go in.
M6
missin full bolt on..
dont have TB, intake or pulley
pulled: 384/373
drives good. does not like to pull under 1200rpm's.
pulls like a **** after 3000
have a graph.............
remember this is w/mods in sig.
gained almost 75 hp from cam and switch from shortis to LT's
M6
pulled: 384/373
Originally Posted by soslo
that seems like an awfully big cam for an auto (if its a daily driver).
