rtv on bottom of front cover?
Old 04-30-2005, 07:07 PM
TJ
TJ's Avatar
Default rtv on bottom of front cover?
ive seen several comments in my searches to put rtv on the flat spot(bottom) of the front cover when putting the oil pan back on.
how many have actually done this? is it a horror story if i dont do it? the gaskets for theses motors dont look like they should require rtv, or i didnt think so.
thanks!
Old 04-30-2005, 07:15 PM
VSGLS1's Avatar
I always put a bead of RTV on the bottom of the timing chain cover to oil pan everytime it comes off.
Old 04-30-2005, 07:19 PM
felton316's Avatar
I always use red RTV on the front and rear covers where they meet the pan. Better safe than sorry. I believe the LS1 rebuild manual says to use sealant (GM# 12378190 or equivalent) at the intersections where the block/cover/pan all meet together .
Old 05-01-2005, 10:12 AM
WILWAXU's Avatar
Never heard any horror stories. Always use a bead of RTV when I remove it.
Old 05-01-2005, 11:05 AM
TJ
TJ's Avatar
thanks guys. buttoning it up today.
Old 05-01-2005, 11:45 AM
ArKay99's Avatar
As said above you should do it. The manual states to use a double bead. Make an elongated ovalfrom the corner to the inside lip of where the front cover will meet.
Old 05-01-2005, 01:39 PM
Cal
Cal's Avatar
I've tried both with and without and couldn't tell any difference except that without you don't have to clean it up next time you're in there.
Old 05-01-2005, 04:30 PM
Beast96Z's Avatar
Good cause I didn't use anything on mine......
Old 05-01-2005, 04:37 PM
GTS346's Avatar
You should put a dab in all 4 corners.
Old 05-01-2005, 04:44 PM
TJ
TJ's Avatar
that i did.
thanks for the help.
motor is done, time for some cleaning and painting now.
Quick Reply: rtv on bottom of front cover?
