Quick axle question
Old 05-01-2005, 08:38 PM
02CamaroZ28's Avatar
Default Quick axle question
wanted to see if I could get someone with experience on the subject before I called the manufacturer.
Will Axles for a 4 channel rear (with reluctor rings) work on a rear for a car with a 3 channel setup?
Old 05-02-2005, 01:32 PM
~JOSHUA's Avatar
Yes it should be OK. The only difference is that the traction control gear would be on there for no reason, but that's not a problem...
Old 05-02-2005, 10:35 PM
Yea i talked to Billingsley about it, and the reluctor ring apparetly can just be tapped off the axle and BING its a 3 channel axle.
