Stereo & Electronics - Installed Autometer shift light, Having problems
matt94z
05-01-2005, 10:34 PM
The shift light will flash when you turn the key on, so I know it should work. The problem is that no matter which rpm pill I put in it, the light will not flash. I was told to tap into the whit wire on the black pcm plug. Is this right? What else can I try??? Help. :bang:
regorih383
05-02-2005, 03:03 AM
Wish i could help but, for what i remember its not the white wier
Chuckels
05-02-2005, 11:29 AM
unbolt the PCM and look for white wire #13 on the RED connector
matt94z
05-02-2005, 05:28 PM
Thanks man, I'll give try that tonight.
dhdenney
05-02-2005, 10:00 PM
I do not have an Autometer light but rather an MSD so I realize different companies are gonna have different schematics for their products. But for comparison: my light's RPM input wire goes to the coil's negative terminal for signal. If you have an MSD ignition, it will have a tach output connector on it.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
