Recommended mods for a 4L60E?
I would like to firm up the 1-2 and 2-3 shifts in my 03 Silverado. Other than an over the counter shift kit, are there any other mods that can be done? I have heard of replacing the servo.....which one to use?
Thanks! Bob
Thanks! Bob
Go with the Transgo 4L60E-HD2 shift kit and a vett servo. You could go with a billet style servo but they are alot more money and for your application you really wouldnt need it. The shift kit should run around $100 and the servo is around $15. Consider a new filter and the cost of the fluid and its a pretty cheep upgrade for the improvement you get. Have fun with it.
Mec
Mec
Mec
Mec
Thanks for the info. Is the stealership the best place to get the servo, or should I check with one of the tranny shops? I have seen two different servos..one for 1-2 shifts and one for 4th gear (O/D). Does the Vette servo cover all gears?
Also, I also forgot to add that I am doing this to help when towing my 21' camper trailer.
Thanks! Bob
I got the Vette servo and a boost valve from a local tranny shop. Installed them before I did the Whipple this weekend. The tranny mods make a big difference. Not tire frying shifts, but not slushy like before either. I will feel better towing with it now -vs- before. Plus the Whipple is awesome!
