The APE 382 is in and running
Finally got it in and running
How to install an engine backwards
http://www.mustangmods.com/data/6571/eng1_001.jpg
http://www.mustangmods.com/data/6571/eng1_002.jpg
http://www.mustangmods.com/data/6571/eng1_003.jpg
http://www.mustangmods.com/data/6571/eng1_004.jpg
Start up
http://www.motorcityoutlaws.com/user...r/1badair2.MPG
Start up
Originally Posted by Bill00Formula
Looks good.
Are you picking up your car using the radiator support?
Only took about an hour to get it bolted in and wired. Would have been better to put the harness on the engine first but we left it in the car
Originally Posted by CAT3
I went through the pics in a slideshow on fast, looped it looks like that car drops on the engine and done in no time.
As far is the procedure goes, that is SLICK - I yanked the motor on an 84 Z28 a few (ok like 15) years ago and hated it!
When you get it tuned and broke in post up a vid of a WOT run (if you do those sorts of things!!)
I will have to get some et radials for the street. I took it up to 4800rpm at half throttle today in third it just spins the Nittos at 26psi.
Tuning in probably two weeks then some WOT video's will follow. Then later this year maybe some 200 shot runs will follow. I don't think the 4.11's will like the N2O. Might have to goto 3.73.
Ya, I learned of this procedure AFTER I pulled and replaced my motor from the top. NEVER again will I do that.
Very nice sounding engine, APE does some great work and I'm sure you'll be more than happy with their product.
I took it out the top about six months ago. After some looking I decided it would be much faster to put it in the bottom. I was going to take it out the top but my old garage door was not high enough to get the car over the engine with the door up. Sure glad I moved a month ago.
hey man, I have my car without anything just like you did, I ? is did you have to pick up the motor and the tranny at all to install it or did you just drop the car into place.. in a couple of weeks I should be receiveing my motor from ape also and It really seems that thats the easiest way to put it in.....
