What HP to look for out of tune tomorrow...
Old 05-03-2005, 08:11 PM
Hotrod God's Avatar
Default What HP to look for out of tune tomorrow...
Hey guys. Tomorrow I am taking my '01 WS6 w/ M6 in to get it tuned. This past winter I installed the following:
AFR 205 heads w/ 66cc combustion chamber and 8019 spring upgrade
Comp cam w/ 228 in.dur. 230 ex. dur. .571 in. lift, .573 ex. lift, 112 LSA
Comp roller rockers w/ 1.75:1 ratio (makes lift ~ .588 in. and .590 ex.)
Comp pro-magnum lifters
Comp Hi-Tec pushrods 7.400
FAST LSX intake
FAST 90mm T/B
Stock injectors (have FAST 36# injectors but think they were too big)
SLP ceramic coated, polished stainless, long tube headers
SLP underdrive pully
Corsa catback system
I was just wondering how much hp to expect out of this combo. I am hoping for 430 rwhp or more. Think it is possable? I would like a good guess, so I can tell if the guy does a good job tuining it tomorrow. They will be using a dyno jet w/ LS1 edit.
Old 05-03-2005, 09:06 PM
M6HuggerSS's Avatar
thats a very nice set-up you got there!
ill guess your baseline will be around 390-410rwhp
and after alot of tune to smooth things out, and then going for power, id say you should be between 420-435rwhp...
let us know how you did!
good luck!
Old 05-03-2005, 11:03 PM
Hotrod God's Avatar
Thanks. I'll put my results up as soon as I get them.
Old 05-04-2005, 02:23 PM
CaptUSA's Avatar
That's going to be bad ***!
How was she driving with the stock tune?
Old 05-04-2005, 02:34 PM
cyphur's Avatar
being the "Hotrod God" i would think you'd know what kind of power it should put down
~430 seems like a good number. AFR's kick ***.
Old 05-05-2005, 05:00 AM
98A4LS1's Avatar
Nice setup! 425 ponies after a good tune. Let us know.
