New LS1 Owners - Newbie Tech - what mod to do next?
mph476
05-03-2005, 10:59 PM
takin it slow as to not make mistakes.... the car is an 02 camaro m6..so far list includes:
slp lid
kooks LT headers w/carsound cats
gmmg exhaust
dyno tune
whats the next step?
Wnts2Go10O
05-03-2005, 11:03 PM
ported tb, cam, pulley, rear, rims and tires, heads, rockers, clutch, shifter...etc..? pick a couple :)
tripps
05-03-2005, 11:07 PM
Exactly as Kickass put it. I honestly would do the small things, then work up. SO ported TB by Bo White, ASP pulley, and then go for the cam. That should do you just right.
evo.end3R
05-03-2005, 11:55 PM
im not putting money towards a nice tune until after my cam is in
blkZ28spt
05-04-2005, 12:11 AM
Do you plan to run much at the track? Do you want good track times or a powerfull street car to cruise around in? If you plan to race it much get drag radials, clutch, and 12 bolt rear. That will eat a good bit of money. If you just want more power and healthy exhaust note get a cam/spring kit.
Little things: subframe connectors, ported throttle body, lower control arms, gears (if keeping the 10 bolt for awhile).
mph476
05-04-2005, 04:34 PM
I really want a strong performer on the street...
blkZ28spt
05-04-2005, 04:37 PM
Cam, gears, subframe connectors, ported throttle body, pullies, drag radials. Take your pick, depending on what you want to spend. If you decide on a cam read the stickies, JRP's cam guide, and search before you ask which cam you should get. ;)
mph476
05-04-2005, 05:27 PM
any negative side effects to changing the pullies?
blkZ28spt
05-04-2005, 06:37 PM
Some people have charging issues at idle. EIther go with only the crank underdrive, or add an alt overdrive as well. They are typically worth a solid 0.1 and 1 mph. Or close.
The old man
05-04-2005, 06:41 PM
Strut tower brace.
Phoenix 2001
05-04-2005, 07:34 PM
I would do a head and cam package, then work my way down.
Phoenix 2001
05-04-2005, 07:52 PM
I noticed you said you would like a strong street performer, keep in mind in 06 the new Z06 will have 500HP and the new Cobra's will 450HP. So you really should consider a Head and Cam package.
kkkevvvinnn
05-06-2005, 10:28 PM
heads and cam are good...but on the cheaper end maybe pullys, pro 5.0 shifter, TRUE DUALS! (I love them!)
kkkevvvinnn
05-06-2005, 10:30 PM
you could always throw a 12 bolt in and some good ass tires to hook up with to
DD966
05-07-2005, 05:24 AM
If street racing is your "cup-o-tea". I'd seriously consider a nice 125 shot of N2O with all the safety equipment. It's relatively cheap, you will sacrafice ZERO streetability, and it will increase your hp/tq more than all of those other mods combined. Good Luck.
evo.end3R
05-08-2005, 12:27 PM
Thanks all, i got a few more mods, and now waiting on some suspension parts and whee;ls/tires...not hooking up at ALL on fuzion Zr1's(had to get them was in emergency needed tires quick) Im gonna throw on some nittos or just get a set of 15" and get some slicks..
Dynoed 334hp/342tq stock :)
