what sealant to use on intake rocker bolts?
Old 05-04-2005, 11:04 PM
WS6FirebirdTA00's Avatar
Default what sealant to use on intake rocker bolts?
what kind of sealant can i use on the rocker bolts for the intake side to keep any oil from possibly leaking down in the chamber? i read using locktite on all bolts but i wouldnt think that would be good enough to keep oil out
Old 05-04-2005, 11:21 PM
xssive's Avatar
ARP thread sealant or red rtv silicone
Old 05-04-2005, 11:30 PM
ok thanks
Old 05-04-2005, 11:43 PM
Cal
Cal's Avatar
Teflon thread sealer is said to work. I don't put anything on mine; I don't think they leak much at all anyway.
Old 05-05-2005, 09:08 AM
where could i get some teflon thread sealer? and would it be any better to use over red rtv?
Old 05-05-2005, 10:12 AM
Cal
Cal's Avatar
Home Depot, Lowe's, plumbing shops. Either one will work.
Old 05-05-2005, 10:14 AM
GuitsBoy's Avatar
Are you guys talking about the white teflon tape?
Old 05-05-2005, 10:16 AM
Cal
Cal's Avatar
No it's a white paste in a tube. I don't see why the tape wouldn't work, though.
Old 05-05-2005, 10:22 AM
ok thanks ill try the hardware store today
Old 05-05-2005, 03:05 PM
NHRATA01's Avatar
I used the teflon paste they described above when I did my heads this winter.
Old 05-05-2005, 10:42 PM
TJ
TJ's Avatar
i knew i forgot something..... dang it.
oh well, if it smokes it prolly not the rocker studs anyway.
Old 05-05-2005, 10:52 PM
went and got some tonight from auto zone, heads should get bolted down tomorrow
Old 05-05-2005, 10:57 PM
Tally TransAm's Avatar
i either used the teflon paste **** or black rtv, i dont really remember but it was one of the two
Old 05-06-2005, 12:05 PM
BriancWS6's Avatar
I used medium strength (blue) loctite on my pewter car when I installed the cam, and torqued them to spec, no problems whatsoever.
Old 05-06-2005, 12:44 PM
That's what she said...
TheBlurLS1's Avatar
i've taken mine off 40 times and never put anything in the holes
it doesnt smoke, and the only oil loss is from my oil pan leaking
i would be worried about using RED LOCTITE on any aluminum parts. that **** can do some damage. i've used blue on a few things (like tq arm bolts), but that's it, i've never put loctite on aluminum parts before.
Old 05-06-2005, 09:39 PM
MrDude_1's Avatar
you dont want to use RTV.
if you do use RTV for some reason, use permatex since not as easily effected by the fuel
when they say locktite, they dont mean locktite the thread locker. they are refering to locktite thread sealant.
threadlocker does work OK to seal it up, but its not as effective.
Old 05-06-2005, 09:58 PM
i used the teflon gel, worked great
Quick Reply: what sealant to use on intake rocker bolts?
