Stock bottom end question
The ARPs will let you spin higher with less chance of rod breakage (especially in pre-2001 cars). But- does your cam make more power up there? Are your valve springs up to it?
Originally Posted by Redlinez
I'm wondering how much the stock bottom end can handle rpm wise. I've been told 6700 or so, I shift at 6600 and I feel I'm leaving rpms on the table. Would I get away with 6800-7000 if I put in ARP rod bolts?
There's two kinds of ARP rod bolts; with the "Performance" series you shouldn't need to resize. The "Pro" series is the ones you should resize with. Katech's are probably the best bet though very expensive; $9 a bolt x 16 = $144 so about $150 with shipping.
