PVC Question: T1 Cam (108 ICL), 5.7L 0.030 Milled Heads?
Old 05-05-2005, 10:05 AM
Sold The Fun Stuff :(
josh99ta's Avatar
Default PVC Question: T1 Cam (108 ICL), 5.7L 0.030 Milled Heads?
If I were running a 221/221 .558/.558 112 cam (108 ICL) on 5.7L heads that had been milled 0.030, would I be OK on PVC with 2.02 intake valves? Also, using stock thickness head gaskets, what length of pushrods would I need and is there anything else I'd need to make the geometry of the valvetrain work correct with the milled heads?
Old 05-05-2005, 10:26 AM
Alssiri's Avatar
I've been running 2 cams with same specs (MTI B1 114 & C1 112) with MTI stage 2 heads milled 0.030 with no problems.
Ahmad
Old 05-05-2005, 04:27 PM
josh99ta's Avatar
Good deal. One more. With 5.7L milled (0.030) heads, what is the static compression ratio with stock pistons?
Old 05-05-2005, 04:50 PM
BrentB@TEA's Avatar
what head gasket?
Old 05-05-2005, 08:12 PM
jrp
SN95 Director
jrp's Avatar
10.91 - 11.3 depending on gasket thickness.
Old 05-05-2005, 10:42 PM
josh99ta's Avatar
Stock gasket thickness I suppose. I'd like to be at an even 11.0 but wouldn't mind being a little under that. Wouldn't want to be much over.
