Where To Mount The Bottle???
I have a 15lb bottle...where is a good place to mount it?? I was thinking on the hump between the two back seats(I removed my back seats)....Click on the link to see a picture of someone else with it done..THANKS
http://www.cardomain.com/member_page...1_736_full.jpg
I just postsed about this not long before you asked
https://ls1tech.com/forums/nitrous-oxide/317196-finished-bottle-install-pics-inside.html
You can cut and bend the stock NOS brackets so you can bolt it directly through the tunnel. Before you start drilling on the tunnel reach under the carpet on the drivers side and pull the fuel pump harness off the sid eof the tunnel. It secured with some stick on clips.
Originally Posted by MetallicaMatt
i'm going to hijack a little bit
will the 15lb bottle fit in the spare tire area?
I have ttops so I need the back empty...any other nice places to mount my bottle?
