truthful cam help
truthful cam help
I have a stock bottom end and am going to get afr 225's and am looking for a cam to max maximize my heads but be an excellent daily driver. I am also ording a 90/90 set up for this and will be spraying a 150 shot. 12 bolt with 4.10's and it is a m6. your help is very much needed. I also like rough idle.
Define excellent daily driver. Some people wouldn't go larger than 220 or 224 and consider it an excellent daily driver. I consider my cam excellent for a daily driver. You can't really MAXIMIZE the heads and be an excellent daily driver. Have to sacrafice one or the other to an extent.
I mean i want it to be very reliable. Like if i take a 200 mile trip i don't have to worry about springs. I really want to get a good set of springs and that be it. Never to have to worry about them again unless something just happens.
Yeah, I didn't even catch that. Why are you so set on the AFR 225's if you're wanting a smaller cam. If you get those heads I'd suggest getting a cam similar in size to the MS3 as suggested above. That would be a great combo.
I never said any thing about a small cam. If I am going to put a cam in my car I will put a big one with big heads. I like to leave myself with no room to go bigger. That is why I want the 225's. I was leaning towards lg x3 or x4, ttp equilizer or the f-15 ron jeremy. i just was asking which big cam is pretty easy on springs from those who have had experience with them.
Are the AFR 225 62cc out?? otherwise you would have top mill the 72 cc a good .036 just to get a 66cc chamber. That alone will eat a little flow.
More and you'll flycut on a huge cam.
G5X3 with 205's and flycut have been making some awsome power. I don't see the point of running a big H/C without at least 11.0:1 SCR and that requires flycutting.
