General Maintenance & Repairs - a popping in turning
AnthonyConstant
05-07-2005, 11:31 AM
While driving.....when ever i go to turn right or left, to merge into another lane or make a turn to another street. i feel one slight pop in the steering.
what could this be?
AAron
05-07-2005, 11:33 AM
id look under there and make sure all the bolts are tight.
TwoFast4Lv
05-07-2005, 11:43 AM
most of the time this happens you will find the front lower contol arm bushings worn out. turn the wheels all the way left or right (check both) and you may find ripped,torn or cracked bushings where the A arm goes to the chassis
The95Firehawk#250man
05-09-2005, 04:14 PM
yeah man i had a V6 camaro that did that. we thought it would need a new rack and pinion or something but all they did was tighten some bolts and it was good after that
moderate Z28
05-10-2005, 10:51 PM
Hey 2fast! Where can one find that bushing? Im having a hard time finding one.
SmokedOutZ28
05-11-2005, 03:15 AM
Could be ball joints or tie rods lift the front of the car and "shake the front end down" and check for unusual play.
big dave
05-11-2005, 09:01 AM
I have the same problem too. It is my lower ball joint
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
