Heads Install - Good News / Bad News
Old 05-07-2005, 11:58 AM
Ed Blown Vert's Avatar
Default Heads Install - Good News / Bad News
Finally got my 6.0L heads installed and it fired up on the first try
Heads
Heat cycled the springs. Changed the pulley from a 4.10 to a 3.70. Set the tranny to shift @ 6200 instead of 6800.
Went for a test run. Hit 10# of boost @6800.
Check the tune and adjusted it again for 6200.
2nd run, hit 8# of boost @ 6300. Then started to hear a little knock. I am guessing a rod.
Timing was still set @ 17* and no detonation.
Knock
Old 05-07-2005, 12:37 PM
BrentB@TEA's Avatar
bummer
Old 05-07-2005, 12:38 PM
Tranzor's Avatar
Ouch... I'm sorry man... I hate the feeling of getting everything back together only to have something else get f@cked up.
Old 05-07-2005, 12:46 PM
I just have to figure out what it is. Bottom-end or valvetrain.
Old 05-07-2005, 02:48 PM
OMG found the problem. Crank bolt back out and sheared the pins on the MMS pulley.
MMS Pulley
Old 05-08-2005, 02:47 AM
Lvmyz28's Avatar
No video of the car driving? Glad it wasn't serious! I'm jealous of your procharger!
Old 05-09-2005, 08:30 AM
GuitsBoy's Avatar
MMS Pulley
Good to hear you got off easy this time
Old 05-09-2005, 09:40 AM
BrentB@TEA's Avatar
wow. It sure could have been worse.
Shouldn't keep you down too long. Gotta really tighten them crank bolts or they will back out everytime.
Old 05-09-2005, 09:46 AM
SideStep's Avatar
It is over-kill but I pin every one I do....
***Edit***
Was this already pinned???
Old 05-09-2005, 09:58 AM
JZ'sTA's Avatar
Damn nice to hear a problem happen with such a easy fix.
Old 05-09-2005, 02:04 PM
No it wasn't pinned. I tighten it as best I can, used Red Loctite. Being an A4, tough to hold the engine from turning.
Old 05-09-2005, 04:05 PM
SS SLP2's Avatar
THIS will hold the a4 and enably you to tighten bolts
Home make a tool to hold crank to allow tighten pulley bolt, insert the tool into flywheel , remove round plug ( about 2-3 inch dia. ) on bottom of of flywheel cover to insert tool
make tool useing flat bar about 12-14 in long
1/4 x 2 x 14 ( notch in the side will allow the tool to hold itself in place by cetching on side of hole)
botton out pullet flush with end of crank with old bolt ,install new bolt torque to 37 lb then pull another 120 degrees if you do not have a compass to get the right degrees ( stop and think ) mark the bolt at 180 degrees and at 90 degrees then mark 1/2 between the two marks which i think will be about 135 degrees so you may go eather 140 degrees or 120 degrees from there ,
sorry the picture does not show up correct, tool
should be about 2 in WIDE
Old 05-09-2005, 06:36 PM
pdd
pdd's Avatar
you need to torque that baby to at least 200ftibs , loctite or not, to seat it correctly. the manuel says 240ft, but i always hit 200 and never had a problem
Old 05-09-2005, 07:44 PM
Well we used a break-over bar with a pipe and tighten it as tight as we could. Not sure how much torque, but we couldn't budge it anymore.
Old 05-09-2005, 09:12 PM
1QuickT-A's Avatar
thats probably more than 200ft lbs so you should be fine
Old 05-10-2005, 09:08 AM
LS1TECH Sponsor
foff667's Avatar
I used it...works well
