oil-level with TA girdle
Yeah, fill it until it runs out the stock hole like. If you overfill it, it should just puke the extra out the vent tube. If your vent is blocked or clogged you could have some serious issues. I've changed mine acouple of times and I fill it once, drive the car, and then check it again. It usually takes alittle more fluid after driving it alittle. Should take just under 2 qts.
Originally Posted by LT1-Z28
i thought my pinion seal was leaking so i freaked out... but it was just dumping alot outta the vent tube
