Need Help (98 Camaro SS)
My Shifter is giving me problems, im having trouble putting it in reverse, i have to use my leg to put it in gear, please help if someone knows what i could do..thanks
mine does it sometimes too. i normally just cuss at it and then its back to normal. but there is a reverse lockout solenoid on the side of the tranny, you should check it out and make sure it hasnt come loose
mine does that also... what i usuallty do to help it go in reverse is throw it up in first.. it usually lines everything up nice and then it goes into reverse like butter... if i dont do that i just get a huge thud when the car finally does go into reverse
Originally Posted by luv2spd
Does it grind or is it just hard to get into the gear? If it grinds you most likely have a synchro problem or could be a clutch issue.
