Max jetting for single nozzle?
I have a NitrousWork Single Wet System that can be jetted to 175HP. Does anyone think I can try for 200 or even 250 with larger jets? Of course, I have the motor and fuel system for it. Or do you think the nozzle or soleniods can't flow that much?
I used to have a nitrous works kit on my car a while ago, if they still come with the same solenoids that came with mine you won't be able to go above 175 because they can't flow anymore than that.
you can take the nitrous jet out and you will only flow 175....it is not based on the jet rather then the soloniod....you will have to upgrade the "noid" to get more hp
