Wiring diagram for Zex remote bottle opener please.
Old 05-08-2005, 02:04 PM
Tiger2o69's Avatar
Default Wiring diagram for Zex remote bottle opener please.
I need these. If anyone knows where to get them or could scan them and send them to me I would really appreciate it. All the web page has is instructions for putting it on the bottle which is obvious.
Tiger2o69@hotmail.com
thanks
Old 05-09-2005, 09:11 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
thanks
http://www.nitrousexpress.com/Instructions/opener.pdf
Should be wired the same. I know it is not zex opener but the wiring layout works the same. Trying to help a nitrous user.
Ricky
Old 05-09-2005, 02:38 PM
Tiger2o69's Avatar
Thanks a lot. Ill remember you guys next time I buy some nitrous stuff.
Old 05-09-2005, 04:48 PM
1ORANGEWS6's Avatar
You still have the TNT kit?
Old 05-09-2005, 07:06 PM
Tiger2o69's Avatar
Yes and im beginning to hate it. The power ring first and now the zex bottle opener isnt strong enough to open the bottle. I dont know if its the opener to weak or the bottle too hard.
Old 05-09-2005, 09:05 PM
1ORANGEWS6's Avatar
I didn't us the power ring when I installed mine it was too much of pain to fit. I used a fernco hose with some nuts on the inside to hold the nozzles in place I love setup.
Old 05-10-2005, 09:29 AM
NXRICKY's Avatar
Tiger that open should be able to open the bottle and close it. You may need to adjust the clutch. Also start with the bottle in the open middle postion. If you started closed you may have just tighten the bottle a little to tight that all. Let me know if we can help.
Ricky
Old 05-10-2005, 12:16 PM
Tiger2o69's Avatar
Thanks..
I tightened the clutch but it keeps getting back loose. Im going to put some lock tight on the threads and see if that can hold it
Old 05-10-2005, 12:33 PM
NXRICKY's Avatar
Try not to over tighten the nut and set the clutch to tight. That will compound your problem.
Ricky
Quick Reply: Wiring diagram for Zex remote bottle opener please.
