Quick LS1 ASA Cam Question!!
I am about to purchase the GM LS1 ASA Cam but which springs do I purchase along with this cam.
226/236 Durations
.525 Lift
110 LSA
The LS1 hot cam recommends the 2001 LS6 Springs... but the difference is just the LSA and durations... Lift is the same.
Need recommendations
Thanks
Jason
226/236 Durations
.525 Lift
110 LSA
Thanks
Jason
how much power did you put down?
Originally Posted by 44mag
I used comp 918s with no problems. good solid spring and you'll never have to change them again.
I had LS-6 springs with a hot cam, changed them to 918's when I changed rockers to 1.8's, do yourself a favor and use better springs to start with, this way if you want a higher lift cam later you won't be doing springs again.
