cc of a 5.3 stock head
Old 05-08-2005, 08:38 PM
John Junkins's Avatar
Default cc of a 5.3 stock head
Can anyone tell me the cc of a stock 5.3 heads. Have my set of heads done and need the info. jwcej@msn.com
Thanks and God Bless Our Troops and the U.S., John Junkins
Old 05-08-2005, 09:21 PM
Richard@WCCH's Avatar
They should cc at around 61cc in stock configuration.
Richard
Old 05-08-2005, 09:25 PM
Richard
Richard, And that should put my motor around 11/1 compression on a stock displacement/ bore, correct? Or close to it. Thanks for the info.
Thanks again and God Bless Our Troops and the U.S., John Junkins
Old 05-08-2005, 09:48 PM
oange ss's Avatar
11.04 with .054 gasket
Old 05-08-2005, 10:11 PM
BrentB@TEA's Avatar
I wouldn't run a stock 5.3 head. I doubt it will make as much power as a stock 5.7 head
Old 05-08-2005, 10:17 PM
Bo White's Avatar
I agree, if they are not going to be ported youl be doin good gettin 10 rwhp.
Old 05-08-2005, 11:24 PM
John, Brent and Bo are right. Don't run the 5.3l heads in stock form. The compression increase isn't worth the loss in flow with the smaller intake valves. Have the heads professionally prepped and then enjoy your hotrod. Otherwise stick with your LS1 heads.
Richard
Old 05-09-2005, 06:22 AM
Thanks Guys I'm having a set done as we speak. I bought a used set of Katech heads and was having them cleaned and checked. I was wondering how much was milled off them. They were 853 heads to start with. The machine shop said they check by cc the heads. I need to know what the 5.3 heads cc were to compare and to see how much if any needs milled off. THANKS AGAIN!!!! jwcej@msn.com
Old 05-09-2005, 08:02 AM
BrentB@TEA's Avatar
John the best way to check them is to measure the deck height to short bolt hole height. On a stock head it should be close to 1.6"
Most of them time the chamber is a few CC's larger after porting so if you really want to know how much is milled check the short bolt hole to deck.
Old 05-09-2005, 08:29 AM
blacktransam's Avatar
umm look at the top of this forum.. ls1 cylindar head cc's..doesn't n e one search anymore??
Old 05-09-2005, 06:57 PM
Thanks again for the help!!!!!
Old 05-09-2005, 07:14 PM
transsam's Avatar
just measure it. Go to a drug store and buy a syringe(sp???). See how many MLs/CCs it takes to fill it up. There is your number. Be careful when it gets to the top as water will overfill on the sides. You will get within about 1cc with this method.
Old 05-10-2005, 12:20 AM
DanZ28's Avatar
Brent, is that 1.600" exact and the same for a 5.7L head? Out of curiosity I just measured mine at 1.579". I was supposed to have .035" shaved off the heads (not your heads), but only looks like .021" off. Definately throw my CR out of whack from what I thought it would be.
Dan
Old 07-18-2005, 03:28 PM
GTA91's Avatar
Dan
Yeah, is that 1.600" exact and for 5.7 heads too? I need to check my '98 heads on my LS1. A friend worked them over but we can't remember if we milled them or not and I need to know for my pushrod length.
Thanks!
-Jeremy
Old 04-13-2006, 04:44 PM
GTA91's Avatar
So is the 1.60" measurement correct for a 5.7L head or not??
Old 04-13-2006, 07:27 PM
GTA91, That is what I used to gauge my heads.
But I will check my old heads and get back to you.
John Junkins
Old 04-13-2006, 08:39 PM
GTA91's Avatar
Let me know, thanks!!
*Also, I did the other measurement from the valve cover plane to the deck plane and it actually is parallel... I got about 7.4XX all over the place. I'm about 99.9999% sure my heads aren't milled.
Old 04-23-2006, 11:12 AM
Jeremy, I measured my old 853 heads and the short bolt side is 1.60" it was consistant on all bolts. Hope this help.
Thanks, have a great Sunday and God Bless Our Troops and the U.S.,
John Junkins
Old 04-23-2006, 11:15 AM
GTA91's Avatar
John Junkins
Thanks man, I'm pretty sure mine aren't milled then!!
Old 04-23-2006, 11:35 AM
My new heads were milled .032 ths. I wanted to go with a bigger lift cam. But I'm going to be safe and use my 228R cam with .588 lift. Glad it helped.
John Junkins
