LS6 Valve Springs & Retainers
Old 05-09-2005, 03:41 PM
MdrnMuscle's Avatar
Default LS6 Valve Springs & Retainers
Anyone know of the cheapest place to get 12 LS6 valvesprings and 12 LS6 retainers?
Old 05-09-2005, 03:45 PM
Adrenaline_Z's Avatar
Just some input:
I'd go with an entire new set instead of mixing. If the springs have a good
amount of mileage, the pressures will be different across the valve train.
If not, have all of the springs checked for seat and open pressure.
Old 05-09-2005, 04:06 PM
2xLS1's Avatar
I'm guessing this is for a V6. GM sells the springs individually (12586484) so SDPC--------------> would probably be as cheap as anyone unless you have a hook up at a local dealer. There is no difference between a LS1 and LS6 retainer so find someone who has upgraded to Ti retainers or dual springs and you could get some either cheap or free,
Old 05-09-2005, 04:51 PM
7 Second Club
ty_ty13's Avatar
im actually selling my valve train stuff... it came off an 02 Z... i believe it has the same springs as an ls6... some one please correct me if i am wrong.
send me a PM if interested.
Old 05-09-2005, 06:03 PM
2xLS1's Avatar
Springs are not the same.
Old 05-09-2005, 07:01 PM
7 Second Club
ty_ty13's Avatar
what is the color stripe on the spring sapose to be?
Old 05-09-2005, 07:03 PM
MdrnMuscle's Avatar
Yes it's for my 3800. I need them to run my 1.9 ratio rocker arms. Ok so the retainers are the same between the LS1's and the LS6's? I'm just trying to be as cheap as possible. I know I can get a set of retainers/springs for 100 bucks, but if I can find a deal why not? Also the LS6 springs are 90 lbs compared to my stock 60lbs(I think).
So it's ok to use used retainers but not used springs?
Old 05-09-2005, 07:15 PM
7 Second Club
ty_ty13's Avatar
ive got retainers off my 02 Z also... for all my valve train stuff....seats/seals, retainers, pushrods, springs 130$ or OBO
Quick Reply: LS6 Valve Springs & Retainers
