felpro head gaskets
felpro head gaskets
Will my new felpro head gaskets hold up to about 11.5.1 compression without a problem. I have used these in the past and no prob but not near as much compression i might want to spray a lil in the future as well and dont plan to pull the new heads off anytime soon. If they wont what is the best and reasonable price to get good ones thanks for any help
Originally Posted by JZ'sTA
Too bad comestic takes longer to build a damn gasket then porting company take to port and assemble a head.
And after you have a 1 month wait time on gaskets you get this.
https://ls1tech.com/forums/generation-iii-internal-engine/317890-cometics-leaking.html
I would come UNGLUED all pun intended.
Wait forever only to have them leak. F that.
BTW yes I am currently waiting on a set.
If anyone reads this and has a set of .045's in stock I will gladly buy them and cancel my order.
If you have the standard felpro gaskets would you be so kind as to measure the thickness of the gasket and post the info? Felpros tech line will not release that dimention,just measure them behind the fire ring .
thanks
thanks
We used the standard felpro gasket on my buddies old iron block with 11.6-1 and a 100 shot with no leaks.
The copper spray on the cometics was a trick I picked up from LPE. They used it on all their lsx motors.
thanks guys just got done putting the heads on. Sorry z-ya i didnt get to read in time but my buddy works up at orielys auto parts and i will get him to order another set to measure. But i will get it for ya. I would have had it running again tonight but for some reason on of my intake port gasket was ripped so i have to get a new one tomorrow along with a water temp sensor for the head since mine just broke on me (pos) I think this will be the last time my block will handle head swap. I was scared about it this time since i keep hearing cracking sounds but everything tighten up to specs and seems fine so i will find out hopefully tomorrow evening thanks guys
