If my clutch slips
wrencher
It depends upon what year & if your replacing the stocker.
Then what & when exactly does it slip? Knowing what it does & what was done prior can kinda see what you might get away with.
But your gonna be looking at a disc, a pressure plate & I'd recommend the center bearing & doing at least the slave. Then you could get the flywheel resurfaced, & you should be good to go.
wrencher
Have you hit them up for a warranty if possible or even a rebuild of this clutch set? All those parts are prolly special for that set up only so you may need to replace it all if going with another set up.
I can't find a way to email them or a # to call. All I want to do is replace the broken parts. I want to keep everything else. It was/ is a great clutch.
