New clutch master cylinder
I recently had a new Aussie clutch package installed. I retained the McLeod adjustable master cylinder. It appears I am having some problems with the McLeod and the Aussie combination. I will probably go back to stock master cylinder. I have a 2000 Trans Am. Is there a certain year m/c that I should buy that would be best?
If you're talking an OEM master cylinder, you want an '01+. From what I hear, the Aussie clutch doesn't work too well with anything but OEM, so no adjustable masters.
