Going from SD to MAF creates crappy idle.....
I tuned my idle and RAF table while running in SD mode. Car started perfect whether hot or cold start with no surging (proportional idle turned off). I calibrated my MAF and plugged it back in and my LTFT's are great. My problem now is that when it starts it surges up and down about 500 RPMS for half a minute and then settles down. I tried using the RAF calculator to recalculate my idle airflow but its not helping at all and only makes it worse. I have tried moving my RAF values 5 times according to the RAF calculator and it only makes it worse. My best results are when I leave the RAF table at the same values that made it idle perfect in SD mode(still surges on cold and hot startups). Any ideas how to get idle whether warm or cold to not surge when back in MAF mode. If I go MAFless the idle is perfect again
My proportional idle is still off. Will turning it back on help anything?
Another crappy note is that I ordered a LC-1 wideband to tune my WOT and now APE has gone belly up. Hopefully my Credit Card dispute is refunded and I can order an LM-1 here soon as LC-1's are back ordered well over a month. I really want to go WOT on this beast!!!!
