F13 shift points/rev limiter
Futral says the F13 makes power up to 6800 rpm, with dual valvesprings rated to .650 lift what would you set rev limiter/shift points at?
TIA
TIA
It won't be an issue w/ valve float. Its more of an issue with how high you're willing to spin your motor. I'd say for best track times shift around 67-6800. If you want to make the shortblock last a little longer shift at ~6600.
