LS1 Tech Dual Nozzle Special!!!
OK guys I have put together a dual nozzle kit at a awesome price.
This system comes complete with.
1.Your choice in white or Black Bottle.(The Bottles will have NXs NEW 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value)
Thanks
Dave
Thanks
Dave
whats the easiest way to get ahold of one of these kits? Also is modding the bellows going to be included in the instuctions? Also these are NX bottles? I didnt know they came in black? Do you have a pic?
The best way to order it is to call in your order at 1-866-648-7637 or 254-857-4237.
THe kit comes with instructions on installing the kit.As far as installing the bellow all you do is loosen the clamps in the maff and lid.Remove your stock bellows and install the new one.Pick the spots that you want your nozzles.They should go one in each side of the bellows.Drill your holes.Install the two peice nuts and nozzles in these holes.
The bottles are NX bottles.I order these black bottles for our pricate label systems.I like them better.
Thanks
Dave
Thanks
Dave
PM me for pricing on just the two shark nozzles purchased a kit second hand and they are stripped. I also need a line from under the hood to go back to my a pillar for my manuel autometer gauge. unless you have a hella of a deal on an electric.
what I really want to do is convert it to the maf kit prices on that two please. PS purchased bottle warmer, nx remote opener,fuel walbro fuel pump and a few other things from you last month if that helps.
Thanks
Thanks
PM please $$$ on all extra bits i need,ie: blanket heater, window switch,remote opener,any other little bits i will want to make this an easy and safe to use system. My car is a holden commodore with a 00 vette crate mtr and an accufab TB. It is also MAFLESS with a carbon fibre,kevlar air intake pipe. As i live in New.Zealand do you ship overseas. Thanks.
