Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
welder
Old 05-12-2005, 10:22 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
Default welder
i thinking about purchasing this one http://www.harborfreight.com/cpi/cta...emnumber=91811
would work for doing subframe connectors and other things of that thickness.what else would i need and would it work with a household outlets?
Old 05-13-2005, 09:44 AM
jdustu's Avatar
shoot, if that thing works even halfway good that's a decent deal....you'll need 220 power though.....i don't know a lot about those smaller portable welders, but if 90 amps is the most you are gonna get for stick and 130 for tig, it kinda limits you on what you can do.......the similar lincolns and millers cost way more, but i think you can use regular outlets and 220 and they have a much wider range of output amps and options...
you would need to get the gas/bottle/valve for the welder itself and then obviously electrodes/filler/helmet/gloves ect to actually weld anything....
Old 05-13-2005, 12:22 PM
Camaro_Zach's Avatar
id be very interested in this to if anyone knew for a fact that it did not suck.
Old 12-03-2005, 06:32 PM
bumpin_records's Avatar
man i would like to know about that one too. is it good for building a turbo kit?
Old 12-06-2005, 06:09 AM
smokinHawk's Avatar
i think some of the turbomustang guys got that, it worked, they built headers with it wo it might do what you want it to do, just have to worry will it hold up (but then your only out $300 not over $1000)
and you cant weld aluminum, so if you just need to do steel.
Old 12-06-2005, 12:30 PM
ahowudoin's Avatar
If your a beginner then you would be better off with a mig. Tig takes alot of practice and the arc welds will be harder on thin steel.
Old 12-09-2005, 02:56 PM
snketr's Avatar
Did you get it? I'm interested in it also. I plan on getting myself a TIG for christmas. So, I can build my turbo this winter. I wonder if it'll do stainless?
Old 12-15-2005, 02:26 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think for subframes a GMAW will get the job done.
Old 12-15-2005, 04:25 AM
ezrollin's Avatar
dude, I finished my Subframe Connector install with my 100 amp Easy MIG.
bought it from Harbor Freight
its a flux-wire type.
I will say that I accidently touched a fuel line for half a second.
So you better put something over the fuel lines and be VERY careful!!
you have to have the suspension fully loaded.
you need to know alot about electricity to be safe.
use the pulling technique with a MIG.
Old 12-15-2005, 04:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I love MIG just because it is tough to screw up and it looks like a pretty row of nickels with no slag/splatter afterwards.
BTW: what happens when you "accidentally touch" a fuel line with a welder?
Old 12-15-2005, 08:43 AM
erikthegoalie's Avatar
Im new to welding..so i read a lot of the posts to learn...what is suspension?? is that something with the welder..or the actual suspesion on the car..
Thanks
Old 12-15-2005, 04:29 PM
ezrollin's Avatar
if you accidently touch the fuel lines, it will burn through
welding torches get above 5000*F!
BIG badda boom!!
by suspension, i mean, all 4 wheels have to be level, and loaded.
i've got instructions from UMI on installing them, if you'd like to see.
it sucks being under a car when all that welding flux-wire is burning
through your clothes then through your skin.
leather clothes are good.
use a drag pulling technique on your pool of weld.
Old 12-15-2005, 04:51 PM
LS1FIRE's Avatar
Why would you want such a low quality welder? I weld for a living and no way i would run a lowtech china welder. When it comes to welding dont play around run top quality stuff. I perosonaly own a milller dynasty 200dx. I SMAW my subframe connectors with 6011. If you are seirous about welding get yourself a quality welder. You can get yourself a good lincoln electric MGAW machine for around 500. And a ac/dc 200 amp SMAW welder for around 500 as well.The lincoln and Miller machines last many years with quality peformance. Our main SMAW machine is been used for 20 years and still going.
Take care
Old 12-15-2005, 07:17 PM
ezrollin's Avatar
your calling my Chicago Electric tools
"Rice"?
Old 12-15-2005, 07:48 PM
LS1FIRE's Avatar
"Rice"?
Not calling it rice. Just dont think the quality is high.
Old 12-15-2005, 08:02 PM
ezrollin's Avatar
yup, it was made in china by charlie.
the American type name is fooling
that is funny in an ironic way
this is my second 1. the first was working
fine, until I turned up the power.
I saw a bright flash, and it was fried, I guess. (of course I took it back)
Old 12-16-2005, 04:19 AM
LS1FIRE's Avatar
Couple people i know bought simmilar units and they also failed. I know somone who paid a little more for a forigen one that worked out okay dont know the company. Most places that sell Miller and Lincoln products have a warranty and repair places that specilaze in repairing them localy and parts are easly available. Quality and service is good.
Old 12-21-2005, 12:16 PM
SSRZ28's Avatar
i bought the lincoln 3200HD. does its a flux-core/mig welder with gas hookup. ive welded on subframes and it does a great job. also used it on headers. it will weld up to 5/16.
bought it from home depot for $450
Old 12-21-2005, 01:01 PM
slow96z's Avatar
I looked at the manual for the one shown and it only tigs .024"-.118" material. That's pretty thin.
Quick Reply: welder
