What else can you use with the BGRA?
Old 05-12-2005, 10:46 PM
'72vettebaby's Avatar
Default What else can you use with the BGRA?
I'm sure you can use an aftermarket lid but can you use SLP's aftermarket cold air induction picking up cold air from underneath in front of the radiator on an '02 WS6?
Also is the BGRA beter than SLP's "FlowPac" which uses a high flow lid and the cold air induction from underneath on a '02 WS6?
Old 05-13-2005, 06:55 AM
LS1 Tech Administrator
Patrick G's Avatar
Why would you want to pick up dirty, warmer air from the street level when you could get a cleaner, cooler direct shot of air going from your scoop into your air box?
Ram Air Trans Ams have the advantage of getting air from the front, negating the reason to pick it up from the radiator cavity.
The BGRA helps channel air into your WS6 airbox. You'll only need a high flow air lid (like an MTI lid) to complete the setup. BTW, this should be in the External Section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 05-13-2005, 09:52 AM
I thought I'd posted this in the external...looks like I f***** up. Anyways thanks for the advise. I just happen to have a Volant air intake system for the WS6 Trans Am, picked it up for $50 from a friend. Could I use the BGRA with the Volant system? The Volant system is completely sealed.
Old 05-13-2005, 10:34 AM
777's Avatar
bgra works with a lid only
